2001 Tahoe running cold
Old Dec 11, 2016 | 9:59 AM
Brandon Stout's Avatar
Default 2001 Tahoe running cold
Ok everyone new poster here. I'm having issues with a 2001 Tahoe I just purchased. Very clean vehicle with 175k miles on her but now that the weather is getting into the 20-30s every morning my Tahoe doesn't want to get to operating temperature. I already replaced the thermostat and that had no change in the running temperature. I drive 25 minutes to work each way and its usually 15 minutes of that trip is 75-80 mph in the interstate and it still doesn't get above 170-180 degrees
Old Dec 11, 2016 | 11:36 AM
Welcome to the forum.
What temp. t-stat did you put in? I read once that they are only good for +/-20%.
Old Dec 11, 2016 | 1:50 PM
A 185 t-stat. But the engine isn't getting hot enough for it to open. After I drive it the bottom hose is still cool like the thermostat hasn't opened yet
Old Dec 11, 2016 | 5:56 PM
kevinkpk's Avatar
Not questioning anything, but you could have put the tstat in backwards? Or perhaps the new tstat is bad.
Old Dec 11, 2016 | 6:01 PM
No thermostat isn't in backwards. The one for this Tahoe is a housing with the thermostat made into it.
Old Dec 11, 2016 | 8:28 PM
Put it in a pan of water w/ a thermometer in it and raise the temp. of the water 'til it opens. I'm betting on a faulty t-stat. Not that unusual.
Old Dec 12, 2016 | 6:04 AM
Thermostat isn't really the problem. I can drive for 20 and the engine not get to 175. So even if it was stuck open it may be a different problem that I'm not familiar with
Old Dec 12, 2016 | 4:01 PM
kevinkpk's Avatar
Put a piece of cardboard in front of the radiator, covering 1/3 or so, see if the engine temp gets up.
Old Dec 12, 2016 | 4:02 PM
kevinkpk's Avatar
These tstats might be fail open, could be partially open when it should be closed.
Old Dec 13, 2016 | 2:18 PM
Does the heater blower hot?
