2004 Suburban Starting Issue
Old Aug 12, 2019 | 7:45 AM
set2992's Avatar
Default 2004 Suburban Starting Issue
My 2004 Chevrolet Suburban LT is now having a difficult time starting when first cranking after sitting for some time. It typically starts after 2-3 cranks and always starts right up again after it has been shutdown after running.
I do hear something energizing when I first turn the key on - not all the way to engage the starter. I have experimented and determined if I do this ~3 times for a few seconds each and then turn the key to engage the starter, the car always starts right up.
I suspect the car's problem is fuel related and am hoping it is not a complete fuel pump replacement. Any help out there to diagnose is appreciated. Thanks.
Old Dec 16, 2019 | 11:19 AM
CrystalG's Avatar
Default Sounds like you are hearing the fuel pump engaging when you turn the key
The buzzing/humming noise you’re hearing is most likely the fuel pump engaging. That’s a good thing. From what you described it sounds to me like you’re fuel pressure regulator or fuel pressure sensor might be the culprit. Good luck!
Old Dec 16, 2019 | 11:23 AM
It is probably the check valve in the fuel pump assembly going bad. A few years ago I had that problem and I put a check valve in the fuel line near the tank and that solved my problem without having to change the fuel pump.
HeavyChevy87
Oct 6, 2021 1:59 AM
skram
Mar 23, 2019 9:35 AM
Blessed3
Jul 25, 2013 11:14 AM
Garon
Nov 21, 2011 8:18 PM
bigandy
Mar 30, 2008 5:58 PM
