2005 Chevy suburban
The rear door will not open. If you hit the unlock on the remote or inside the vehicle, you can hear it unlock and when you push button on door and raise door handle, it will not open. There is no way to get the door panel off because the door is shut. Any suggestions?
there is a relay switch behind the panel on the pillar between front and back (or middle) seat that is bad it will click if it is good be sure to check unlock and lock for clicking noise its called the b pillar relay
