2011 Tahoe Misfire
Old Jun 19, 2017 | 7:39 PM
monster dad's Avatar
Default 2011 Tahoe Misfire
Good evening. I have a 2011 that has a misfire cylinder 3 even after the coil, spark wires and plugs and fuel injector have been changed. Service station thinks it is an issue with the cats, everything I have read does not indicate an issue of misfire with cats accept that a misfire will cause a cat problem and not the reverse. Any help is appreciated.
thanks
Old Jun 20, 2017 | 7:13 AM
Do a compression check.
Old Jun 20, 2017 | 7:22 AM
thank you for your response. A compression test was done in the beginning of the fun journey we are on. Shop said compression was great.
Old Jun 20, 2017 | 3:55 PM
Frank3's Avatar
Can you feel the misfire with the motor running?
Old Jun 20, 2017 | 4:26 PM
Yes. Some days it is more noticeable.
thank you for responding.
