99 Chevy Tahoe exhaust leak?
Old Jul 20, 2010 | 10:09 PM
Chevy Heart's Avatar
Default 99 Chevy Tahoe exhaust leak?
When I drive my 1999 Chevy Tahoe I hear a "putt" sound as I drive. I'm not sure if it is an exhaust leak (I can't find one) or if it's time to get a catalytic converter. Is this common for this year Tahoe? I noticed that I am getting a leak of radiator fluid coming out of the block of my engine; around the head. Could the catalytic converter cause such a problem, maybe with too much pressure being pushed back to the engine???
5.7L V8
Old Jul 21, 2010 | 10:18 PM
If the cat is clogged, you'll get a whoosing sound out of the tail pipe under hard acceleration.
Antifreeze leaking out around a head could be a head gasket.
Old Aug 10, 2010 | 8:44 PM
I'll check it out. Thanks for the response.
Old Aug 30, 2011 | 8:51 PM
sg29651's Avatar
Mine was doing that and it was the flange between the exhaust manifold and tailpipe
Old Oct 16, 2011 | 9:53 AM
Gnazti's Avatar
if water is coming from by the heads, it's probably your head gasket. & you would get a trouble code if the catalytic converter was bad, plus have loss of power. tap on the cat with a rubber malet. if you here rattling, then it's bad. you said you here a "putt", it's possible your engine is misfiring
hydrodriver
Astro
Jul 18, 2010 8:13 PM
teefaw
May 27, 2010 10:10 PM
mikevr007
Astro
May 24, 2010 5:56 AM
PastorK
Mar 1, 2010 9:09 PM
95wt
May 30, 2008 3:07 PM
