a/c clutch
Old May 27, 2010 | 8:20 PM
james770's Avatar
Default a/c clutch
My 1997 GMC suburban a/c stoped working. the relay that i found still works and there is power when i hit the switch going into the rear of the compressor. there is no power going into the clutch portion of the compressor and i can't seem to find the clutch relay. Can someone please tell me where to find the relay or switch so i can test it because i is very hot in a black suburban in hawaii.
Old May 27, 2010 | 9:24 PM
MDTAHOE's Avatar
Professional Mechanic
If the refrigerant is low it would not run.
Old May 27, 2010 | 9:46 PM
james770's Avatar
the refrigerant is fully charged. i had it checked just before it went out
Old May 27, 2010 | 10:00 PM
MDTAHOE's Avatar
Unplug the switch on the receiver drier. Jumper the 2 wire together, Does the compressor come on?
Old May 30, 2010 | 1:05 PM
james770's Avatar
yes the compressor came on, but now it is blowing hot air. what is the best way to recharge the system. do they make any refigerant with a dye in it to see where it is leaking from?
Old May 30, 2010 | 10:10 PM
Gorn's Avatar
Yes they do, check out your local parts store. Most of them sell a kit with the dye and a small black light. If its a very slow leak you could try some stop leak.
Old Jun 9, 2010 | 9:47 PM
You also will need a set of gauges to check pressures when it's charged.
pdrayton
10
May 5, 2024 2:27 PM
weltertm
May 13, 2006 4:25 PM
jimbo
Apr 23, 2006 7:27 PM
Infinitrium
Mar 8, 2006 4:55 PM
4mjmu
Nov 21, 2005 9:36 AM
