Front Axle Shaft Seals?
Old Feb 20, 2019 | 8:39 AM
saabman's Avatar
Question Front Axle Shaft Seals?
Hi :-)
I need to change my front axle shaft seals on my 2000 Suburban 1500
My first question is : are they the same left & right?
If so is this part number correct? (sorry about using a vendor site but they have lots of parts info)
https://www.rockauto.com/en/parts/ac...haft+seal,2336
Thank you very much for any feedback about this
S.
Old Feb 20, 2019 | 11:24 PM
when you do the job....the left side shaft can be hammered out...the right side can't...the extension housing must be removed.
Old Feb 22, 2019 | 4:40 AM
saabman's Avatar
Hi
Yes I know that I will have to remove the shaft on that side ;-)
But are the seals the same on both sides? and is that part I mentioned correct?
Thanks for the tip :-)
