No Cruise Control
Old Jun 25, 2017 | 4:57 PM
Testy68's Avatar
Default No Cruise Control
I have been looking thru some archived threads about CC ......I have a 2007 Chevy Suburban 2WD 1500 LTZ (New to me).....The light on the steering wheel comes on however the dash light does not and CC never engages.... checked the fuse (will be checking ALL the fuses over the next couple of days) and just replaced the Brake Light Switch........any other thoughts ??? Thanks
Old Jun 25, 2017 | 8:49 PM
kevinkpk's Avatar
Brake lights work?
Old Jun 25, 2017 | 9:26 PM
Testy68's Avatar
Yes....
Old Jul 15, 2017 | 4:09 PM
Firemanjoek's Avatar
My 07'suburban ltz just started doing same in the last couple days, replaced my brake switch, my #43 fuse under the hood is good so still chasing, if I find anything I will give you a shout
Old Sep 22, 2017 | 12:17 PM
Default Still no cruise control
few months ago I replaced the brake switch and didn’t help, recently a mechanic said it was the clock spring-replaced it and it
still doesn’t work, any other suggestions?
Old Sep 22, 2017 | 3:39 PM
kevinkpk's Avatar
Clock spring is for the air bag. I do know the turn signal switch COULD have CC wiring through it. I'd suspect mechanical since you have the indication
Old Sep 22, 2017 | 5:30 PM
Default Replaced clock spring
teplaced the clock spring, it didn’t work initially but after an hour or so it started working, thanks for the info
Old May 19, 2019 | 5:53 PM
denden's Avatar
New User
Awaiting E-mail Confirmation
2007 Tahoe no cruise.. Blinker controls.. Changed brake switch... STILL no cruise.. Any ideas for next possible step..Thank you in advance
Old May 19, 2019 | 6:00 PM
kevinkpk's Avatar
Blinker as in turn signals or hazard?
Old May 22, 2019 | 3:28 PM
Irish_alley's Avatar
I'm here for the party
is your abs light on?
