OEM Reverse Back-up Camera (Full Parts List)
Old January 14th, 2007, 2:33 AM
  #41
tj
tj's Avatar
Default RE: OEM Reverse Back-up Camera (Full Parts List)
ORIGINAL: biglg
All I got to say, is a I installed a Kenwood 900 today! YEEEEHAAAAWWW. , what do you think about dem apples Fred!
Does the picture show up well at night? I was wondering if this camera had a low Lux rating.
Old January 14th, 2007, 2:47 AM
  #42
biglg's Avatar
I had that same question. However, I just checked it out a few minutes ago. It works great in the dark as well. I guess your reverse tail lights produce enought light!
Old January 14th, 2007, 2:48 AM
  #43
biglg's Avatar
TMW, you dont believe me that I did the install? HAHA
Old January 15th, 2007, 1:13 PM
  #44
tj
tj's Avatar
ORIGINAL: biglg
biglg.....Where & how did you mount this camera? I'm looking at this one too. Do you know if it is weather-proof?
Old January 15th, 2007, 1:15 PM
  #45
biglg's Avatar
https://chevroletforum.com/m_15129/tm.htm
I have about 10 pictures there. I dont know about weatherproof, but I would imagine so. It is made to be installed on the outside of a vehicle so I would think it would be weatherproof.
Old January 22nd, 2007, 7:10 PM
  #46
chip's Avatar
Ok, I am in the mist of installing the camera. Couple of questions:
On the brown plug (C4) I only have 3 wires:
5 D-GN/WH 817 Vehicle Speed Signal (UVC)
6 PK 6972 Camera Signal #2 + (UVC)
7 L-BU 6973 Camera Signal #2 (UVC)
There are no other wires. Can I simply cut wire 6 and 7 and wire them into the camera? Do they have any other function anywhere else?
Also, where are you guys wiring the camera power leads to? I noticed a powerplug on the passenger side in the cargo area that I was thinking about using. I also thought about tying into the reverse lights so the camera is only powered when in reverse. Any comments?
Old January 22nd, 2007, 9:02 PM
  #47
TMW597's Avatar
ORIGINAL: chip
Yes you can hardwire right to the 6 and 7 pins for the video if you'd like. Not sure what to tell you on the power question.
Old January 22nd, 2007, 9:14 PM
  #48
biglg's Avatar
ORIGINAL: chip
Read through this, it should help! https://chevroletforum.com/m_15129/tm.htm
Old January 23rd, 2007, 6:54 PM
  #49
chip's Avatar
I am almost done. All wires are run and connectors are put on them. However, does it make a difference on how the polarity of the video feed is hooked up? If so, which is the postive video feed. I have the power right.
For reference:
Red - positive 6v
black - negative 6v
yellow - ??
white - ??
FYI - I ran the power for the camera off the reverse lights and put the 12v-6b converter behind the passenger side trim piece above the rear tail light (inside). Side note - the rear tail lights are a PITA to get off.
Old January 23rd, 2007, 7:08 PM
  #50
TMW597's Avatar
ORIGINAL: chip
For reference:
Red - positive 6v
black - negative 6v
yellow - ??
white - ??
Sounds like you're all over it. The polarity does matter, and here's the beautiful thing with video. It doesn't matter if you reverse it. Try it both ways, when the video pops up you got it. You won't hurt anything if you reverse it. My assumption is yellow + and white for -.
Quick Reply: OEM Reverse Back-up Camera (Full Parts List)
