Tracker 1989-2004
Platform: CAMI (Suzuki)
'03 ZR2 4wd Transfer Case Fill & Drain Plugs Help
Old Jan 13, 2026 | 1:51 PM
NM03's Avatar
Default '03 ZR2 4wd Transfer Case Fill & Drain Plugs Help
I tried searching the threads without success so I thought I'd post this...
I have a 2003 ZR2 2.5L 4wd and the previous owner butchered the transfer case fill and drain plugs to the point where they are not usable (probably used a 3/8" drive socket head instead of the correct 10mm square socket). I'm trying to find the correct GM/Chevrolet part numbers in effort to locate the correct replacement plugs, but I haven't had any success.
Does anyone out there have the correct GM/Chevrolet part numbers and/or know of a source for the correct plugs? Or does anyone know the correct Suzuki part numbers for the same sized transfer case plugs?
Any help would be appreciated!
Old Jan 13, 2026 | 2:24 PM
L84sky's Avatar
Suzuki part# 09246-16010
Megazip.net says they have them.
https://www.megazip.net/search?q=09246-16010
Old Jan 13, 2026 | 3:31 PM
NM03's Avatar
Thanks for the help!
Old Feb 25, 2026 | 2:46 PM
JKATHRE's Avatar
Yeah, my Transfer drain plug was rounded off and I took the Tracker to a guy I knew. He welded a bolt onto the existing nut. Looks funny but works.
Douglas Spencer
Dec 9, 2018 3:32 AM
jawilker
11
Sep 7, 2012 6:36 PM
jsquared3000
Oct 18, 2009 7:03 PM
dkbrucedvm
Mar 31, 2007 7:10 PM
