Tracker 1989-2004
Platform: CAMI (Suzuki)
2000 Tracker 2.0 L4 Fuel system
Old Mar 23, 2026 | 1:04 PM
padlikehel's Avatar
Default 2000 Tracker 2.0 L4 Fuel system
Hi Guys,
New here. I'm having a problem with my Tracker. Seems like it isn't getting fuel, which I'm in process of diagnosing.
I disconnected the outboard line from the filter, and ran a hose into a catch can to see if the pump was pumping.
I'm seeing that the pump is running for about 10-15 seconds, then no more.
I know that some vehicles will only temporarily run the pump before start up. Does this system do the same thing?
Or should I have pressure at the fuel rail whether it starts or not? Because right now, even though the pump is running,
I'm not getting fuel to the rail.
Thanks in Advance
Old Mar 24, 2026 | 7:30 AM
L84sky's Avatar
I have the 2.5L V6 in my Tracker but my factory service manual also covers the 2.0L. I can answer some basic questions but for detailed 2.0L information you should sign up at the Suzuki 2nd gen forum.
One feature of the 2.0L is the ability to attach a fuel pressure gauge directly to the fuel rail. The adapter is hard to find but I think have a part number if you are interested.
Old Mar 24, 2026 | 10:01 AM
padlikehel's Avatar
Thanks so much for this and the info about the other group. This at least gives me somewhere to start.
MishaZ
Dec 16, 2025 8:16 PM
Smashengineering
Sep 7, 2019 1:43 AM
sfzombie13
Nov 19, 2013 6:02 PM
frenchmexx
Mar 30, 2012 4:03 PM
Beater
Feb 19, 2012 8:52 PM
