Tracker 1989-2004
Platform: CAMI (Suzuki)
1996 tracker idle problem
Old Jan 30, 2020 | 9:32 AM
Cordie Ray's Avatar
Question 1996 tracker idle problem
I have a suzukii x-90 1996.( It's just a Tracker with a different body siting on it) Idles perfect when cold but once it's warm it won't idle at all, but will always restart. Ideas? This is a standard 5 speed 2wd. 107K takes about 15 minutes of driving before it starts acting up.
Old Jan 30, 2020 | 10:51 PM
oilcanhenry's Avatar
Do you have any OBD II codes?
Old Jan 31, 2020 | 9:14 AM
L84sky's Avatar
Below is a partial list of things Chevy says can cause rough idle and stalling. I have never had this problem
with my Tracker but I had something similar happen with my previous car. It would drive normally but the
engine would die every time I came to a stop. It would always start back up and drive off. Turned out the
EGR valve was stuck. Back then an EGR valve was $30. I think they run about $300 for a Tracker so I
wouldn't change it unless I was pretty sure that was the problem.
little red
May 17, 2017 8:35 PM
Tracker2002
Jan 16, 2016 4:25 PM
99trackerdad
Mar 14, 2014 12:57 PM
TJKashin
Sep 26, 2007 2:15 PM
