Tracker 1989-2004
Platform: CAMI (Suzuki)
2000 Tracker Crank sensor?
Old Sep 30, 2021 | 12:59 PM
Vance in AK's Avatar
Default 2000 Tracker Crank sensor?
My son purchased a 2000 Tracker 2.0l 4x4. Its been running fine. Started it yesterday morning & it was running well. Left it for awhile to warm up & when he came back it was running very rough. Brought it to me & the catalytic converter was smoking when he arrived. Engine sounds like it's dropping one cylinder and when in gear at idle runs extremely rough, visibly rocking & bouncing. Oil level etc is fine. Friend with a code reader pulled a code P0335 crankshaft position sensor A circut. Does that make sense with these symptoms?
Old Sep 30, 2021 | 4:43 PM
L84sky's Avatar
It does not. The crank sensor is only used to detect engine misfires. It does not affect engine performance.
Old Oct 1, 2021 | 2:33 PM
Thank you sir!
Old Mar 16, 2022 | 10:45 PM
thefew's Avatar
Check out the live data and the other codes that are stored but not setting the Service Engine Soon light.
Then come back and explore this forum a little more. Somebody on here has already encountered your issue. I haven't yet...knock on wood.
Smashengineering
Sep 7, 2019 1:52 AM
RoosterP
Nov 6, 2014 8:39 AM
cfilion88
Sep 23, 2012 6:13 PM
FlyingOkra
Nov 10, 2010 11:03 AM
carol360
Dec 30, 2006 5:40 PM
