Tracker 1989-2004
Platform: CAMI (Suzuki)
2000 tracker - reset button?
Old Dec 21, 2022 | 4:08 AM
FritzM's Avatar
Default 2000 tracker - reset button?
Just bought a 2000 tracker. On the first trip the drive belt broke and the engine overheated before I realized what was happening. Now there's no spark. ?? Is there perhaps a fuse or a reset button for overheating? I've looked everywhere, can't find anything.
Old Dec 21, 2022 | 5:26 AM
L84sky's Avatar
There is no reset button and it is unlikely an engine overheat would blow a fuse. The signal that tells the PCM when to fire the spark plugs originates at the Camshaft Position (CMP) sensor. These are known to be sensitive to heat.
The 2 liter engine uses a 3-pin Hall effect CMP sensor.
If you have access to an oscilloscope, look for a pulse train on pin-2 of the CMP sensor while cranking the engine.
I'm not the familiar with the 2 liter CMP sensor but I believe you can replace the black electrical part without disturbing the timing.
I don't thik the part is very expensive but again I am not that familiar with the 2.0L.
Old Dec 21, 2022 | 11:04 AM
FritzM's Avatar
Thank you, L84sky. I will check this out. All new to me and very interesting. I will be very fortunate if the problem is this simple to fix.
FritzM
Old Dec 21, 2022 | 11:10 AM
L84sky's Avatar
Let me know what you find.
Smashengineering
Sep 7, 2019 1:52 AM
Flpmurphy
Mar 8, 2018 5:38 PM
CACTUS24
Jun 5, 2011 7:38 AM
FlyingOkra
Nov 10, 2010 11:03 AM
carol360
Dec 30, 2006 5:40 PM
