Tracker 1989-2004
Platform: CAMI (Suzuki)
2001 Chevy tracker oil leak
Old Jun 1, 2021 | 5:00 AM
Brettkb's Avatar
Default 2001 Chevy tracker oil leak
Hello, we have a 2001 Chevy tracker with a oil leak.
we changed the valve cover gasket already. Would anyone know what is causing this leak?
Old Jun 1, 2021 | 9:23 AM
Clean it real good with Gunk and then watch it closely to see where it is coming from. I would guess that it is coming from the timing cover oil seal.
Old Jul 28, 2021 | 12:26 PM
arhenry's Avatar
Default Oil leaking
Try the front crankcase main seal.
Old Jul 28, 2021 | 12:28 PM
arhenry's Avatar
Check the front crankcase main seal.
Old Jul 29, 2021 | 6:23 PM
2001 chevy silverado's Avatar
That's looks like a very slow leak. They were designed that way.
#1 jiffy lube over-fills oil that causes high oil pressure and oil to push on seals
#2 dirty oil carries dirt under the seal: and you can't get it out, then it leaks and only gets worse
if it's a slow leak just clean it once in a while before it drips. that looks like a very slow leak.
in the day they made that car they laughed at a drip of oil on the drive-way. literally.
also - that's pretty close to the oil filter. for all i know the oil filter was left loose two oil changes ago.
also - jiffy lube is greate at spilling oil on the top-side. that can leak down over days and seem like a leak when there is no leak.
until i see some damaged concrete - i'm not worried even a tiny bit
Old Aug 2, 2021 | 10:03 AM
Domino3665's Avatar
I am not a big fan of snake oil additives BUT...
I had a substantial leak on the front main seal. For $15, I tried a bottle of Blue Devil rear main seal stop leak.
It WORKED.
It has been about eight months now and no leaks. I still can’t believe it.
It takes about 400-500 miles for the magic to happen. But...YEAH.
”Two thumbs way up.” 👍👍
Tim Price
Mar 11, 2020 11:40 PM
Tim Price
bcalde07
Jun 18, 2018 9:30 AM
Josh2
Aug 19, 2014 6:13 AM
