Tracker 1989-2004
Platform: CAMI (Suzuki)
2001 Tracker 4dr 2.5L ZR2 Rear Differential
Old May 24, 2023 | 6:38 PM
mgc9383's Avatar
Default 2001 Tracker 4dr 2.5L ZR2 Rear Differential
2CNBJ734016949954 Does anyone have any ideas on where to buy differential parts? My tracker has 136K miles and is in great shape. No rust. I just replaced the water pump, timing chains and tensioners. The rear end makes noise. A whole new carrier or maybe a different diff from a different car that will fit? It's all stock with 4x4, ABS and 4.88 gears in the rear.
I'm also looking for a replacement passenger front fender flare as well. No salvage yards near me have one for a ZR2
Old May 25, 2023 | 6:15 AM
L84sky's Avatar
My 2001 LT has the same powertrain but I am not qualified to give advice on differentials. I suggest you post your question on the Grand Vitara forum since you are essentially looking for Suzuki parts. If it helps there is a salvage yard in Arkansas that specializes in Trackers and Suzukis. They might be worth a phone call.
Old May 27, 2023 | 4:40 PM
mgc9383's Avatar
Thank you, I'll give that a shot
Old May 29, 2023 | 10:16 AM
Domino3665's Avatar
Salvage yard and some OOMPH is probably your best bet. Good luck! 👍
Tracker21
Oct 3, 2022 7:13 AM
bushlander
Apr 5, 2021 9:59 PM
Trevor Brandt
Mar 8, 2021 4:56 AM
Rhianna Brown
Dec 4, 2016 8:49 PM
tracker91
Feb 18, 2013 7:42 AM
