Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 Chevy tracker brake caliper bracket bolts
Old Sep 4, 2018 | 5:55 PM
American Abstract Inc's Avatar
Default 2002 Chevy tracker brake caliper bracket bolts
Hello ,
I'm having a hard time finding any info on the brake caliper bracket bolts that mount the guide to the knuckle. Any help is greatly appreciated .
Thanks
Old Sep 6, 2018 | 5:31 PM
oilcanhenry's Avatar
Originally Posted by American Abstract Inc
Hello ,
Thanks
Can you expand what what you wish to know?
Old Sep 6, 2018 | 5:35 PM
I'm trying to find replacement bolts . I've searched and all I can find are the caliper slide pin bolts . The caliper bracket bolts seem to be rare.
Thanks
Old Sep 6, 2018 | 6:48 PM
Thanks
Looks like Raybestos and Dorman make them:
https://www.partsgeek.com/catalog/20..._bolt_kit.html
Old Aug 27, 2020 | 9:37 PM
AndysNJ's Avatar
Those raybestos and dorman bolts are NOT caliper bracket bolts. They are the caliper slider pins and the corresponding locking bolts for those pins. The “Caliper bracket bolts” are for bolting on the bracket that holds these pins so that they can hold the caliper in place.
anyway, I’m also having a hard time finding the caliper bracket bolts for this model. (2003 Chevy tracker)
autozone and advance don’t list them in their systems.
Napa didn’t seem to want to bother to dig around and look.
many ideas?
Old Aug 27, 2020 | 10:06 PM
Harley Peters's Avatar
many ideas?
Hi there. What I ended up doing is going to a bolt supply store, took the bolt out in the parking lot and found a bolt that would work spent about $5-10 on bolts and lock washers. When you park, if you turn the wheel so the rear of the tire is sticking out you can feel around and find it. I found Bolts that are threaded all the way up to the head unlike the factory bolts that where smooth part of the way. I have checked them every other service when I rotate my tires and the treads are undamaged. It was a few month ago that I changed mine out but I think the the pitch of the threads is 1.25 and and the with of the bolt is 12M (sorry I can’t remember the length) make sure you get a grade 8 or 10.9 bolt or stronger as that is the factory bolt strength. Also call and ask the bolt supply store before you go, in the area I live a lot of the stores don’t carry metric fine thread anymore.
Tip: buy some anti-cease and put it on almost every bolt you take out of your tracker, makes things a lot easier to work on in the future, especially if you live somewhere where the salt the roads in the winter.
Best of luck!
Old Aug 28, 2020 | 1:32 AM
L84sky's Avatar
Is number 18 what you are looking for? If so start here https://catalogs.ssg.asia/suzuki/?la...VwSWQ9PTU4OTQ2
Old Aug 28, 2020 | 7:34 AM
Take one of the old bolts to a fastener store and they should have it in all the hardness varieties. I have done this before.
