Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 chevy tracker squeal at 800 to 1200 RPM
Old Oct 13, 2012 | 12:24 AM
nels5's Avatar
Default 2002 chevy tracker squeal at 800 to 1200 RPM
I have a manual transmission 4x4 tracker with 2.0 engine. The car squeals from 800 to 1200 RPM
when I am accelerating (I am in 2,3 or 4 th gear - almost lugging the engine). The squeal
happens for 1 to 2 seconds then goes away. It only happens at this RPM range. I replaced
the idler pulley and the tensioner last week and that didn't stop the squeal. I cannot get
it to squeal if I park the car and rev the engine at this same RPM range so I presume
it some drive component causing this and not related to the water pump/alternator.
Old Oct 13, 2012 | 5:49 AM
pegrizz's Avatar
Wheel bearing? Why are you winding it out like that?
Old Oct 16, 2012 | 10:38 PM
nels5's Avatar
It is only 800 to 1200 RPMs, I can take a look at the wheel bearings but I think it is unlikely since it is only when I have it a low RPMS then put into 2 or 3 rd and accelerate. If I do anything else there is no noise.Thanks
Nickel33
Aug 17, 2014 11:13 PM
msl3idtc
Jun 20, 2012 5:51 AM
Nodakchevyguy88
Oct 9, 2011 10:12 AM
dacrew4009
Jul 7, 2009 6:48 PM
