Tracker 1989-2004
Platform: CAMI (Suzuki)
2003 Tracker 2wd L4 2.0 base
Old Nov 9, 2025 | 1:18 PM
jkrisp2025's Avatar
Default 2003 Tracker 2wd L4 2.0 base
I have a noticeable shimmy while braking at a stop light with the brakes applied. New motor mounts and tranny mounts installed. RPM seems good at about 850ish. Engine seems to be running smoothly otherwise. Shimmy goes away when driving. Any thoughts or suggestions?
Old Nov 10, 2025 | 3:48 AM
L84sky's Avatar
Replace your warped rotors or have them turned at a machine shop.
Old Nov 10, 2025 | 2:01 PM
jkrisp2025's Avatar
Thanks. I will check into that.
Old Nov 10, 2025 | 7:37 PM
-Nate's Avatar
Not sure how warped brake discs could make it shimmy when stopped......
Old Nov 11, 2025 | 4:09 AM
L84sky's Avatar
The original post said: "...a noticeable shimmy while braking..."
Old Nov 11, 2025 | 7:24 AM
-Nate's Avatar
Thumbs up Can't Reed Gud =8-)
So it does ;
I saw "stop light" and went off course .
Old Nov 11, 2025 | 11:00 AM
L84sky's Avatar
I've done worse.
Old Nov 11, 2025 | 11:12 AM
Rednucleus's Avatar
I read this as shimmy or vibration when sitting at the stop light, not while moving. @jkrisp2025 please clarify!
Old Nov 11, 2025 | 12:09 PM
L84sky's Avatar
If shimmy means "rough idle" then I withdraw my rotor diagnosis and replace it with this:
LM2025
May 5, 2025 4:05 PM
Banjoron
Apr 20, 2022 9:15 AM
Country6683
Aug 19, 2021 2:16 PM
tttmex
Aug 6, 2018 6:16 PM
Antonio Sc
Apr 11, 2012 11:17 AM
