Tracker 1989-2004
Platform: CAMI (Suzuki)
2004 tracker
Old Apr 8, 2023 | 6:46 AM
Mike Manfredonio's Avatar
Default 2004 tracker
4 wheel drive light flashes with right directional.
Old Apr 8, 2023 | 3:42 PM
L84sky's Avatar
Usually this kind of problem is caused by a bad ground.
The indicator bulbs make contact with two pads (one 12 volts, one ground) on the instrument cluster. Some times there will be green corrosion on the copper pads. Somes times there is in invisible oxide layer. A pencil eraser will remove the oxide layer.
Old Apr 8, 2023 | 5:30 PM
thank for the info
Old Apr 8, 2023 | 5:46 PM
L84sky's Avatar
I only have schematics for a 2001 Tracker and even then they don't show much detail inside the instrument cluster. In general, current takes the path of least resistance. So if the turn indicator had a high resistance ground connection you might expect the current to find a ground through another bulb. The odd thing here is the 4WD indicator doesn't have ground until the PCM gives it one. This may turn out to be a difficult problem to solve. I'm keen to learn what you find find.
Domenic Curulla
Jul 21, 2020 5:45 AM
billp591
Jan 16, 2019 9:58 PM
bellabella
Jan 18, 2016 8:17 PM
2004 Red
Aug 16, 2015 10:02 PM
vette
Nov 24, 2014 7:15 AM
