Tracker 1989-2004
Platform: CAMI (Suzuki)
AC Fuse keeps blowing
Old Nov 15, 2012 | 4:37 PM
LittleFeat's Avatar
Default AC Fuse keeps blowing
Hi all
I have a 2002 Tracker ZR2 (2.5L DOHC V6) with an AC fuse that blows everytime I turn on the AC. I heard a loud squeal coming from under the hood the night before this started. I have been driving it for about a week with no AC, around 250 miles, no squeals. So I have a couple of questions.
1. Is my belt going to break and leave me stranded?
2. What should I expect to spend repairing this?
Thanks
Old Nov 15, 2012 | 4:53 PM
kevinkpk's Avatar
Compressor, and about 500 bucks.
Old Nov 16, 2012 | 8:47 AM
LittleFeat's Avatar
Thanks Kevin
Is this a DIY job or should I have it done by a mechanic?
Old Nov 16, 2012 | 2:50 PM
kevinkpk's Avatar
Originally Posted by LittleFeat
Thanks Kevin
I took mine to a reputable shop. You'll have to recover the system, then pull a vacuum on it to check for leaks, and if the compressor "ate itself" the system will have to be evacuated. Also if you buy a compressor without the clutch, you have that to deal with.
Old Nov 16, 2012 | 4:11 PM
LittleFeat's Avatar
Thanks again Kevin
I did some more snooping around and i agree, this isn't something I want to tackle on my own. I did talk to a good mechanic friend and he told me I should be all right driving it this way through the winter. As long as the pully is spinning. It does appear that the clutch is cooked. He said as long as I don't replace the fuse, the clutch won't try to kick in and cause more trouble.
Now my next question is ... where in blazes is the pcv valve? I found a blow up that says it should be at the back end of the valve cover on the drivers side but I must be blind because I'm not seeing it. Any ideas?
Old Jun 24, 2013 | 6:49 PM
Redbone007's Avatar
New User
Awaiting E-mail Confirmation
Hi.. my was the ac cooling fan in front of the rad.. soon as you turn it on ..pops the fuse..unplug the fan at the connection .. n you will have to replace the condenser(cooling) fan ..in the process of pricing and changing the unit..hope this helps ..
hunteredpete
Jan 30, 2016 8:25 PM
stretchslocum
Aug 22, 2008 10:28 PM
clwill65
Astro
May 15, 2008 4:53 PM
Mercpuman
Jul 11, 2007 12:03 AM
kathedi
Jan 2, 2007 9:14 PM
