Tracker 1989-2004
Platform: CAMI (Suzuki)
Camshaft Position Sensor Replacement
Old Feb 3, 2018 | 11:38 PM
03ZR2V6's Avatar
Default Camshaft Position Sensor Replacement
Hello Tracker Owners. New to this Forum. Can anyone please tell me the steps to replacing the Camshaft Position Sensor in my 2003 Tracker ZR2 V6 engine? Also where can I buy a service manual, prefer the actual book. Thanks everyone.
Old Feb 4, 2018 | 2:31 AM
oilcanhenry's Avatar
Actual books on repair are becoming obsolete these days it would seem..
Old Feb 4, 2018 | 8:39 AM
There is one on Ebay but it is expensive.
https://www.ebay.com/sch/i.html?_fro...anual&_sacat=0
Old Feb 4, 2018 | 8:26 PM
03ZR2V6's Avatar
Thanks oilcanhenry. I'm old school,I prefer the book.
Thanks oldchevy,I saw that. Don't know why they are expensive.
Now I just need the proper steps to changing the camshaft position sensor,please help.
Thanks all
Old Feb 6, 2018 | 8:54 PM
03ZR2V6's Avatar
OK I screwed up today. I managed to get 1 of the 2 torx screws out and yes I got the easy one out and I managed to screw up the one at the bottom and rounded the torx screw. Is there a way of removing the torx screw out without having to remove the intake? Those torx screws were really tight and I had a little trouble in getting the easy one out. Any help is much appreciated. Thanks all
Old Apr 16, 2018 | 8:05 PM
03ZR2V6's Avatar
Finally got the Camshaft position sensor replaced also changed the valve cover gaskets and the intake gaskets. Problem now is, I need to set the timing properly as it's not running right. I get a bit of a hesitation from a stop position and also got a flashing service engine soon after about 30-45 minutes of driving and got a pending P0300 code . I think it has something to do with the timing. How do I set the timing? Please help. Thank you all
Old Apr 23, 2018 | 8:04 AM
Domino3665's Avatar
Default YouTube!
It may sound silly, but you won’t believe how much good info is available on YouTube that addresses car problems and fixes. If you can’t find a fix right away, change up your search words and try again. I have had amazing success finding answers to problems, even rounded screw heads. Good luck!
