Engine washed and now it wont run
Hi All new here just got a 2003 Tracker 2.0 2 wd 4 dr for my wife. My friend wanted to help so he washed the car including the engine. After that it would not start anymore.
Just bought this with 175000 miles clean and was running. it did idle rough but started fine and ran. check engine light on since i got it but ran fine. now since the engine got wet i dried it with air and sprayed wd40 and let it sit all day. still wont run. checked IG fuse ok no spark at coils. pulled codes and it has a code for crank sensor which was not there before it got wet. wetting engine did not take out crank sensor. also has code for o2 sensor since i bought it too.
i was told it could be cam sensor does that sound right? way too costly to throw parts at it to see what works need to be sure
any suggestions?
any suggestions?
GP1969
Avalanche
Apr 18, 2013 5:31 PM
BlackDenali
Sep 20, 2007 12:11 PM
