Tracker 1989-2004
Platform: CAMI (Suzuki)
first time doing CV joints 2003 tracker zr2
Old Aug 14, 2020 | 4:09 PM
nat8's Avatar
Default first time doing CV joints 2003 tracker zr2
i have done a fair share of my own work over the years but this is a first for me. im trying to make sure i have all the tools i need before i start taking anything apart. ( hard to run to the store with the tracker on blocks). what size of socket do i need for the axle nut?
thanks all for your time.
Old Aug 14, 2020 | 6:05 PM
L84sky's Avatar
Dear Nat,
I'm assuming the CV joints on your car are similar to my 2001 LT 4-door. The driver's side is no problem. Remove the wheel. Unbolt the axle from the differential. Remove the snap ring. Wiggle the axle out. The passenger side is a different story. You have to remove the shock. This is a major undertaking. The fact that you think there is an axle nut involved suggests you may be in over your head. If you decide to go forward set aside two days because the learning curve is steep. One tool you absolutely need is the Harbor Freight ball joint puller (below). It also works on the tie-rod ends. You really should have the step-by-step repair instructions in front of you while you are working. Before you do anything read through this person's experience. https://www.suzuki-forums.com/thread...1999-gv.37983/ I will try to answer any questions.
Old Aug 14, 2020 | 10:55 PM
Instead of separating ball-joints, can't you just unbolt one control arm and drop the knuckle out of the way?
Old Aug 15, 2020 | 4:36 AM
L84sky's Avatar
In theory you could remove the control arm but the control arm is the only thing holding the coil spring captive.
If the strut is in place and the wheel hub is fully lowered, the coil spring is still under compression.
That spring is dangerous. But even if you could remove the control arm without getting your teeth knocked out,
how would you ever get the control arm back in place? There's little to no room to get a spring compressor in there
and the spring rate is so stiff that trying to compress it with a floor jack just lifts the car off the jack stands.
99trackerdad
Mar 14, 2014 12:57 PM
Antonio Sc
Apr 11, 2012 11:17 AM
TJKashin
Sep 26, 2007 2:15 PM
