Tracker 1989-2004
Platform: CAMI (Suzuki)
Heater Problem
Old Jan 15, 2015 | 2:57 PM
tcwhisper's Avatar
Default Heater Problem
Hello all. I am working on my Grandmothers 2001 Tracker ZR and the problem she is having is that there is no heat coming out of the vents and defroster unless the RPMS are above 2000 when selector is on outside air. The engine temperature is operating within normal ranges. Did not check it on recirculate to see if it functions properly. Any ideas wold be great. Thanks
Old Jan 19, 2015 | 1:30 PM
Domino3665's Avatar
Have you looked at the cabin air filters? There are two of them under the passenger side dashboard area.
Old Jan 21, 2015 | 8:35 PM
tcwhisper's Avatar
No I have not the air flow from the fan motor is good. I have seen when they are plugged you get no air flow. But will check thanks for the help
Old Jan 22, 2015 | 9:34 PM
Tmurphyh's Avatar
How does the coolant look if it has rust or corrosion it could possibly be a clogged heater core take a hose and some cleaner to try to clear it out
Old Jan 24, 2015 | 8:36 PM
tcwhisper's Avatar
Coolant looks good flushed heater core still no heat unless going 35 mph or rpms above 2000
Old Jan 31, 2015 | 1:15 PM
Rednucleus's Avatar
I assume coolant level is up? My sub did this when the water pump was leaking and the coolant level dropped a bit. You could hear fluid turbulence in the heater core. Wonder if you have air trapped in the system?
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
thejum57
Jan 7, 2007 5:15 AM
rpl47
Jan 6, 2007 2:48 PM
GraigH
Nov 28, 2006 2:00 PM
jake 1369
Dec 20, 2005 4:02 PM
