Tracker 1989-2004
Platform: CAMI (Suzuki)
How to replace v belt?
Old Jul 13, 2014 | 7:48 AM
treeboom's Avatar
Default How to replace v belt? 2001 tracker
How do you replace front v belt. I removed fan but am now stuck. 2001 tracker
Last edited by treeboom; Jul 13, 2014 at 8:01 AM. Reason: Need year .. miss spelling
Old Jul 13, 2014 | 10:56 AM
therewolf's Avatar
Hi treeboom,
Welcome to the Chevy Forums.
Generally speaking, the alternator is on a slide bracket.
Loosen the bracket, slide the alt inwards, change the belt,
then re-tension the alternator, and secure the bolt at the slide
first, then the pivot bolt. UNLESS the system has a tensioner
pulley, which is spring loaded, in which case, you merely de-tension
the tensioner pulley, replace the belt, and release the tensioner.
Check the thread search for Tracker. And remember, Google is your friend.
Old Jul 13, 2014 | 8:47 PM
treeboom's Avatar
Default got it 2 bolts one wrench pivot
I figured it out. It was small flat belt crank to fan. 3 - 14mm headed bolts. Loosen upper and lower bolt middle is a pivot for wrench to tension belt after replacing. Note fan must come off but that is how I started my thread because I had fan off and did not know how to proceed.
landon101
22
Nov 14, 2021 10:48 AM
OtherCarASaab
Aug 31, 2012 12:00 AM
davethewav9
Jun 4, 2011 11:29 AM
rsmith7964
Oct 27, 2009 6:14 PM
hollijb
Feb 12, 2007 12:21 PM
