Tracker 1989-2004
Platform: CAMI (Suzuki)
Need help finding thermostat housing.
Old Feb 27, 2019 | 7:14 PM
jessica helmer's Avatar
Default Need help finding thermostat housing.
Was changing thermostat in a 2002 ZR2 2.5l 4wd and the housing cracked. Can not find another anywhere. Suggestions? Also I was changing the thermostat because there’s no coolant going into the radiator from the overflow, anybody have this issue?
Old Feb 27, 2019 | 8:02 PM
L84sky's Avatar
I'm not familiar with a 4.5L Tracker engine. If you meant 2.5L this might help.
https://monsterfactoryparts.com/part...iagram=F751030
The radiator cap is what allows the fluid to be pulled out of the overflow reservoir. I would change that first.
Old Feb 27, 2019 | 8:08 PM
Default Thanks
Sorry, Icorrected my post, 2.5l. And we did change the cap, that didnt fix the issue. Even if it did the housing is still cracked 😕 The link above is not the correct line up. My housing only has 2 bolt holes, not 3.
Old Feb 27, 2019 | 8:16 PM
L84sky's Avatar
Use the link above to order a new housing. Replace the hose from the reservoir to the radiator. If it's cracked it may be sucking air instead of coolant.
Old Apr 24, 2022 | 6:10 PM
Rich Engle's Avatar
Default Thermostat on lower hose
The thermostat is on lower hose port.
Old Apr 24, 2022 | 8:29 PM
L84sky's Avatar
You are absolutely right. I don't know where I got that picture from. This diagram is from a Suzuki parts catalog.
