Tracker 1989-2004
Platform: CAMI (Suzuki)
Need help: Fuel leaking from passenger side rear wheel well area
Old Jul 7, 2022 | 5:23 PM
NHTracker02's Avatar
Default Need help: Fuel leaking from passenger side rear wheel well area
Only leaking gas when running so pretty sure it’s not the tank. Pretty significant leak. Any ideas? Fuel line or something else?
Old Jul 7, 2022 | 8:16 PM
L84sky's Avatar
Crawl under the car from the rear. Look up into the space between the rear axle and the fuel tank. Locate fuel filter in photo above. Inspect the rubber hose between the fuel filter and steel lines that go to the engine. The presssure in that line is 30 psi when the fuel pump is running.
Old Jul 7, 2022 | 8:33 PM
Thanks for the lead! I’ll check it out tomorrow morning. It sounds like you might be right bc it’s spurting out with some force.
Old Jul 7, 2022 | 8:42 PM
L84sky's Avatar
Protect your eyes. The fuel pump will run for three seconds each time the key is turned to ON. No need to start engine.
bode
1988 - 1998 (GMT400)
Nov 16, 2020 12:33 AM
wolfdogg
Oct 3, 2019 12:55 AM
Seth Fowler
Cobalt
Nov 20, 2018 7:07 AM
ohyeah96
Mar 13, 2018 8:06 AM
greenfiresocks
May 7, 2011 2:58 PM
