Tracker 1989-2004
Platform: CAMI (Suzuki)
OB Code PO440
Old Jul 24, 2011 | 7:12 PM
elrodalonzo's Avatar
Default OB Code PO440
Anybody had any luck fixing a tracker 2.0L with the above code EVAP system no flow during purge? Thanks.
Old Aug 3, 2011 | 6:12 AM
This is the most useless, pathetic forum I've ever seen, glad my other vehicles are Fords!
Old Aug 4, 2011 | 6:15 AM
You're probably right. The Tracker is a 99 four door, green, 110,642.3 miles, tires are about half worn, it has a few native bugs on the windshield, and is normally driven in a north to south and south to north direction. I will wait for the replys to flood in. Thanks in advance!
Old Aug 4, 2011 | 7:36 PM
Thanks for your reply Einst, but I was kind of looking for somebody who had the same problem and actually fixed it, not an armchair mechanic. The system is quite simple and after my tests the fuel vapor canister fails the test described in my Haynes manual but in my experience with other cars they very, very rarely are the culprit. There is a purge valve but that is working properly. I suppose I should replace this first but they are hard to find and very expensive and I'd like to hear from some people who had similar experiences.
Vinna
Nov 12, 2012 8:51 AM
Gregory Agee
Oct 25, 2012 8:32 PM
GM Fixer
Mar 19, 2012 7:09 PM
leomazzone
Jul 9, 2008 8:26 PM
ashortkid
Mar 28, 2008 9:52 PM
