Tracker 1989-2004
Platform: CAMI (Suzuki)
PO328 knock sensor high voltage
Old Dec 22, 2025 | 6:12 PM
Jflash's Avatar
Default PO328 knock sensor high voltage
As a computer tech in the 70&80’s thought chasing a code PO328 knock sensor would be easy, but after ordering some cheap parts from Amazon I started checking for continuity and knock output, having found what I believed a good one. I cleared the code and for 3 days all was good, then came back. When I clear the code it returns immediately . I have visually looked for chewed wires, loose connections. Replaced spark plugs, Filled gas with 92 octane,no help. Tightened as many grounds as I could find, didn’t see braded engine ground. I can’t hear any pinging or knocking noise but I wear hearing aides. Any suggestions would be appreciated.
Thanks . Jack
Old Dec 23, 2025 | 12:14 PM
L84sky's Avatar
I'm assuming you have the 2L inline four because my V6 does not have a knock sensor. All I can offer is the troubleshooting flowchart for the P0328 DTC in the factory service manual.
Old Dec 24, 2025 | 4:00 PM
Jflash's Avatar
Default Troubleshooting
Thank you for providing TSC that should really help.
Old Dec 24, 2025 | 4:49 PM
L84sky's Avatar
I found this after a little more digging in the 2.0L section:
jfmorris
Aug 22, 2024 3:01 PM
mrbreez55
Mar 25, 2019 6:48 AM
hondaman
Jun 18, 2011 3:39 PM
betterdays
Mar 14, 2011 7:07 PM
stcspiderman
Aug 17, 2010 12:26 PM
