Tracker 1989-2004
Platform: CAMI (Suzuki)
Tank replace compatible interchange Vitara
Old Dec 12, 2014 | 11:40 PM
AceTechOne's Avatar
Default Tank replace compatible interchange Vitara
There's an unanswered thread about this already, so I figured I should post anew.
Need a new Tracker tank, mine's leaking on a seam.
I'd prefer to not braze/weld it if possible (not as simple as a motorcycle tank).
2002, 4dr, 2.0, Canadian build.
Is there a specific model/config. of the Vitara which might have the same tank as 2nd gen. Trackers? Seems like someone must know!
I've found the fuel tank/system fiche to be identical between Tracker/Vitara more than half of the time, but it's not something I trust.
Sure, there's a dealer with the GM tank online, would be ~600.
Tracker Gen 1 tanks I've seen brand new are only 60-90 shipped!
Hundreds of Vitara tanks on Ebay/salvage sites for ~200, while only 0 Tracker tanks on Ebay, and few salvaged.
BTW: I'm in Maine, not a good source of unrusted salvage parts around here!
these are the notes I've made in searching:
fuel tank
gm ?OEM 91173553? doubt
suzuki tank vitara xl-07, grand etc correct years at least: 197-59217
Suzuki tanks from fiche identical to mine: 8910167D02, 8910167D21
2002 Suzuki Vitara Air And Fuel Fuel Tank Grand 2 5L | Used Auto Parts | HollanderParts
197-59217
GM oem
**176534 TANK FUEL (NOT AVAILABLE) EJ1 (L34,CV3)
**176536 TANK FUEL (NOT AVAILABLE) EJ1 (L34)(EXC CV3)
**021600 STRAP F/TNK SHLD (NOT AVAILABLE) EJ1 2 01-02 -- --
**021600 STRAP F/TNK SHLD (NOT AVAILABLE) EJ1 (L34,CV3) 2 02 -- --
**022855 INSULATOR F/TNK STRP (NOT AVAILABLE) EJ1 2 01-02 -- --
**022855 INSULATOR F/TNK STRP (NOT AVAILABLE) EJ1 (L34,CV3) 2 02
-nalleygmc fiches I use so far: 91176536 "EXC Mexico". bing finds 38 results.
or 91176534 just says "Mexico" tho looks as if works ALSO with Canadian, considering above table. bing finds 125 results.
although both of those #s say works in the 99-00 S10 pickup 2wd, if I view parts for the s10 manually, shows only 91176534 listed -however specifies Mexico. S10 was probably only made in Mexico.
"3 models from 1999 till 2004. This part is genuine General Motors part with GM OEM-code 91176534 from group #03.001.
Tank dimensions is 15.50 in × 36.50 in × 22.50 in. Whole package with tank weighs 22.99 pounds."
"3 models from 2001 till 2004. This part is genuine General Motors part with GM OEM-code 91176536 from group #03.001.
Tank dimensions is 24.30 in × 38.30 in × 22.30 in. Whole package with tank weighs 20.70 pounds."
justinfriend61
Sep 11, 2009 8:48 PM
throne7
Oct 30, 2007 3:06 PM
Derek2023
Oct 17, 2007 7:29 PM
joel davis
Sep 20, 2005 3:46 PM
