Tracker 1989-2004
Platform: CAMI (Suzuki)
Tracker 101: intro to the BRAKE warning indicator
Old Nov 1, 2020 | 12:57 PM
L84sky's Avatar
Default Tracker 101: intro to the BRAKE warning indicator
A number of instrument panel warning lights illuminate when the key is turned to ON.
One that doesn't is the BRAKE warning indicator.
If the BRAKE warning lamp does illuminate, one of these 3 conditions exists.
1. The hand brake is not fully released.
2. The brake fluid is low.
3. The key is in the START position.
The ground from the hand brake switch is also used to inhibit the DRL's with the car in daylight and the engine running. If the hand brake switch was
jumpered or wired directly to the BRAKE warning light (instead of relayed by the DRL module), the brake fluid switch could inadvertently inhibit the DRL's.
The START circuit serves as the lamp test for the BRAKE warning indicator. The ignition switch (above) is drawn in the START position to show the path for power and ground to the BRAKE
warning indicator. When the key springs back to the ON (run) position the BRAKE warning light extinguishes because the ground is removed from the indicator light.
Jdugan92
1988 - 1998 (GMT400)
Nov 2, 2020 8:28 PM
R.R
Dec 28, 2013 9:36 AM
bkordrs
May 15, 2011 11:05 AM
taw2db
Nov 6, 2009 5:25 PM
ubique
Mar 25, 2008 3:31 PM
