Tracker 1989-2004
Platform: CAMI (Suzuki)
Tracker 101: intro to the junction block connectors
Old Nov 16, 2020 | 5:41 AM
L84sky's Avatar
Default Tracker 101: intro to the junction block connectors
This is a photo of the eleven connectors visible on the front of the of the junction block. There are three connectors
(C1,C2 & C3) that I cannot locate. I suspect they are on the back of the junction block. If you know where they are,
please share. What follows are the 2001 Tracker circuits for each plug. I tried to fix the errors in the service manual
but it is unlikely I have found them all. I will make corrections as they are brought to my attention.
Starting at the top right corner and going clock-wise, the first connector is C216.
The next connector is C203.
Then C201.
Followed by C202.
Then C4.
and C5.
Old Nov 16, 2020 | 5:49 AM
L84sky's Avatar
Still going clock-wise around the bottom is C204.
Next is C205.
The first connector up the left side is C213.
Next is C207.
And finally the last visible connector is C206.
The connectors I cannot find are:
Old Aug 9, 2022 | 8:58 AM
ardevor01's Avatar
So from my testing and everything with trying to find the wires I need to install a remote start. There is a brown w/ yellow (possibly red w/ yellow) in C213 towards the top right when it is plugged in. I'll get better info when I finish the install. Also C202 doesn't have a ground on mine, the one is Ignition Positive voltage, and I forget the other but I'll update more once I am finished. Mine tracker is a 2003 so I'm not sure if these diagrams apply exactly or not.
L84sky
Nov 17, 2020 8:14 AM
L84sky
Nov 8, 2020 5:59 PM
L84sky
Nov 8, 2020 7:05 AM
TheGageinator
Jul 18, 2020 11:28 AM
zoomazoomzoom
Jul 18, 2020 11:24 AM
