Tracker 1989-2004
Platform: CAMI (Suzuki)
Wont shift out of park after horn blew up
Old Aug 10, 2016 | 9:29 PM
garrett970's Avatar
Default Wont shift out of park after horn blew up
Today my 2001 trackers horn started going off and I couldn't get it to stop. After 5min or so of honking smoke started to emerge from the hood area then made a loud pop and the horn stopped. After letting it sit awhile I removed the fuse that the horn uses (not the dash fuse box but the fuse box under the hood. I got in and started it up to take it home and look at it but it would not shift out of park.
After fighting it for awhile I took off cover and was able to use my finger to push the switch towards the rear of the car and put it in drive to get it home. (It said to do this in the manuel) As Soon as I got home i put it in park and its still doing the same thing. Not coming out of park unless I use my finger to push that small latch.
My question is what could cause this? It all happened at once with the horn blowing today.
Please help. Thanks in advance
Old Aug 11, 2016 | 8:35 AM
the shift interlock solenoid is probably powered by the same fuse as the failed horn circuit.
this solenoid must be powered to allow a shift out of the park position.
Old Aug 11, 2016 | 1:15 PM
garrett970's Avatar
Yes sir. Fuse was blown. Changed fuse and all is good exacpt the horn don't work which I don't need. But should I remove the horn or what should I do? Is the short still active??
Old Aug 11, 2016 | 1:45 PM
check for power at the horn wire when the horn is pressed and released. if it works normally, change the horn. leave it unplugged for now.
