03 TB LS NO start
The wife took the tb for a short ride and it stalled, i towed it back home and when i turn the key the rpm and spedo gauges go wild and the throttle body is clicking along with the neutral safety switch. At first i could hear the fuel pump running and it would start but die shortly after. Now the fuel pump no longer runs. Any thoughts? THANKS!!!
possibly the vcm/bcm went bad you should have advanced auto parts plug in a tec II and see what it says.. The bcm controls the ignition as well, without that i know you can not start the vehicle. try to unplug the bcm under the passenger seat in the back behind the drivers seat and turn the key to turn on all the electronics then turn it back to turn off the electronics and plug it back in which might reset the bcm. If that dont work you can try unplugging both the battery terminals then try that method. If you plug in the code reader and it doesnt get a reading at all most likely it is a bad bcm. I am currently having problems with my bcm as well.
I unplugged the bcm and did that also i unhooked the battery, had no effect to my problems. There is no power most of the time to the starter however sometimes it will roll over. Also the fuel pump will no longer run.
well if you checed all sensors, relays and fuses and you are still having major electrical issues i would recommend to get your bcm flashed or replaced because that is the only thing i know of that would cause such problems. i just reset my bcm which fixed a few problems in my trailblazer but now i have to install a new throttle body control unit.
Finally the problem is fixed! I tested the ignition starter switch and it tested fine, picked up a new one just to be sure and installed it and sure enough it started right up
Thermool
Jun 20, 2009 6:41 PM
wildboy74ss
Apr 1, 2009 5:10 PM
izod
Feb 14, 2009 2:42 PM
larry_chip
Jun 2, 2007 3:20 PM
