TrailBlazer 2002-2009
04 Trailblaser leaking water on pass floor when ac is on.
Old Aug 23, 2011 | 9:51 AM
mixedbreed's Avatar
Default 04 Trailblaser leaking water on pass floor when ac is on.
I have a 04 trailblazer that leaks water on the pass floor when the a/c is running. The a/c blows cold and everything works but just pooling water.
Does anyone know where to find the evap case and the drain hose for the a/c or have a pic of them. Oh and I checked to be sure and it is water and not coolant.
Old Aug 23, 2011 | 12:04 PM
kevinkpk's Avatar
Drain is plugged up on the evap core. There should be a drain hose that allows condensation water to drain to the ground, look for that it is plugged, and water is draining on your floorboard.
Old Aug 24, 2011 | 9:51 AM
mixedbreed's Avatar
Thanks but i already knew one of them was clogged, I was asking for the location of the drain line lol. Its all good though I found it yesterday and when i pulled off the drain line about 1 1/2 gallons of water came out. Everything is good now. It was on the pass side firewall right next to/ below the a/c lines.
rickmack21
Uplander
Aug 13, 2021 2:20 PM
OkieMudslinger
Apr 26, 2013 3:41 AM
1bolt
Mar 13, 2010 7:39 PM
shepdog25
Jul 31, 2009 5:31 AM
rtmtrrdr
May 22, 2009 7:06 AM
