TrailBlazer 2002-2009
'05 "thud" sound
Old Apr 6, 2012 | 10:19 AM
jtlonghorn's Avatar
Default '05 "thud" sound
I had the transmission replaced in this rig w/ 110,000 miles on it....the dealer messed up the ATF change and wrecked the transmission, so they put a different one in.
Fast forward two weeks. The tranny overall works fine, however I'm now chasing a noticable "thud" sound that occasionally happens after I come to a complete stop at a stop sign. As soon as I completely let off the brake to continue forward this thud occurs. It doesn't happen every time, doesn't cause the car to jerk, and I can't get it to do it by just slowly going down the road and coming to complete starts/stops. Seems like the car had to be going 35 mph + prior, then coming to a complete stop.
I've checked out all of the U-joints and they are solid. One time the sound seems like it's in the back end, the next time it's under me.....very hard to tell.
Thoughts?
Old Apr 6, 2012 | 11:31 AM
You need to grease the slip yoke. this is a fairly common problem and the grease is recommended and works. I usually put some grease in at oil changes since mine has a grease fitting.
Old Apr 8, 2012 | 9:53 AM
jtlonghorn's Avatar
So I assume I disconnect the driveline where it connects into the output shaft of the transfer case....then slip the yoke out?
Thanks.
Old Apr 8, 2012 | 10:52 AM
Yes, Clean out the old grease as best you can and then pack new grease into it. Heavy-Duty Grease NLGI #2 is recommended. I have also heard that Marine wheel bearing grease is good.
ts021784
Oct 20, 2011 5:36 PM
chevyman323
Jul 16, 2010 11:56 AM
brendan
Mar 1, 2010 4:27 PM
mike688
Uplander
Jan 25, 2010 12:16 PM
metalmike187
Dec 16, 2009 10:07 AM
