06 Trailblazer Accelerator Pedal Sensor replacement - BOLTS
I have purchased replacement Accelerator Pedal Sensor Assembly for my '06 Trailblazer LS. The original is bolted to panel under dash, next to steering column. The bolts are horizontal to my view, and very tight space. I was able to remove bottom two bolts with short #10 wrench (the everyday-type ratchet with #10 cannot fit) , but cannot access the top (last) bolt (#10's). How does someone reach way up in that tight area and get that 3rd bolt out? Suggest tool other than my everyday-type ratchet or short #10 wrench?
Gilbert Correa
27
May 9th, 2024 10:21 PM
blondy_3000_00
January 21st, 2012 8:07 PM
handrade_satx
June 17th, 2009 6:41 PM
GolfClapperX
February 19th, 2008 11:21 PM
