2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
08 Impala LT 3.9L accelerator pedal position sensor replacement
Old May 6, 2011 | 9:28 AM
blondy_3000_00's Avatar
Default 08 Impala LT 3.9L accelerator pedal position sensor replacement
Does anyone have any helpful information, a "how to" guide or photos on how to replace the accelerator pedal position sensor? Also, can this be done at home or does the sensor need to be "taught" by a dealer or computer?
Any and all information is greatly appreciated and thank you in advance!
Here is the problem I am having:
As I try to take off from a stop light I can push the pedal and the car does not react...does not race the engine, does not move at all then all of a sudden my car takes off. After doing other research on the internet I believe this sensor is the problem and needs to be replaced.
Old May 6, 2011 | 11:24 AM
EinST's Avatar
Welcome to the forum. Unfortunately problems like yours take more than throwing parts at the problem. Consider taking it in for service. If you are still covered by the 5yr/100k powertrain warranty, even better.
Old May 7, 2011 | 11:48 AM
Thank you for your input. Do you, or anyone else, think that I have diagnosed the cause of my problem correctly? Could something else be causing this problem?
Old May 12, 2011 | 10:30 AM
Official GM Rep
If you would like some more in depth information on your vehicle you may want to look into getting a service manual for your vehicle at www.helminc.com. I am unable to comment on whether or not your diagnosis of your vehicle would be correct. I hope these suggestions offered to you help you.
Jeff Morris, Chevrolet Customer Service
Old Jan 21, 2012 | 8:07 PM
zrdc28's Avatar
Smile How to change impala accelerator app sensor
This is one of the simplest jobs that you will ever find. NAPA, Auto zone has them for about $60. You will need a 10 mm socket,rachet & extension along with a small flat blade screwdriver. First remove the 2 bolts that holds the accelerator pedal down, next use the small screwdriver to push down on the clip on the connector & unplug. Do everything in the reverse order to install. There is no learning curve for the computer it just works. I did my 2009 impala in less than 10 minutes after find tools. This cleared the p2138 & p2127 codes from coming on.
Gilbert Correa
27
May 9, 2024 10:21 PM
TigeInGA
Dec 13, 2014 12:14 PM
Saskatoon_Jim
Jan 28, 2012 12:03 PM
handrade_satx
Jun 18, 2009 7:52 PM
handrade_satx
Jun 17, 2009 6:41 PM
