TrailBlazer 2002-2009
AC problem
Old Jun 13, 2014 | 7:54 AM
xwendell1's Avatar
Default AC problem
Troubleshooting the intermittent AC. AC quits cooling when abient temp gets in mid 80's and driving in stop and go traffic. Compressor not turning or engaged when it is not working. Compressor cycles on and off, but mostly off. High side line gets hot when compressor engaged but not enough to make me take my hand off. Cooling fan is good. Jumpered across low pressure plug but compressor still cycles mostly off. Works perfectly when ambient temp is 80 or below even in stop and go traffic. Has anyone run in to this issue or have any recommendations on how to determine if the compressor is going bad or something else is shutting it down.
Wendell
Old Jun 13, 2014 | 10:57 AM
I think the first step would be to see if the system has a full charge of freon.
Old Jun 13, 2014 | 12:00 PM
xwendell1's Avatar
Had the system vaccumed and recharged first thing. I should had indicated that in the troubleshooting steps. When it is running, the high side and low side pressure is good.
Rosariods
Jul 21, 2011 8:13 PM
BayAreaChevyGuy
Jan 6, 2011 2:27 AM
chenzo
Mar 21, 2010 5:35 PM
99silver
Feb 2, 2008 4:14 PM
Yesi
Oct 8, 2006 6:27 AM
