TrailBlazer 2002-2009
Blazer won't start
Old May 20, 2014 | 11:09 AM
Cougar69's Avatar
Default Blazer won't start
The other morning started her up, no problem
Moved her into position to tow my dead mower then stopped her got out went into house did a couple of things got back in and turned key nothing apart from the lights go out and radio goes off?
Battery is good, it's an auto and one thing I noticed is that the P N D 3 2 1 on the dash are lit up but no light to indicate what gear you are in, even when you move the selector?
You can bridge the starter motor and she will turn over, so starter not dead...
Any ideas much appreciated....
Old May 20, 2014 | 10:44 PM
pome's Avatar
Im not a technician, make sure your shifter is in park or nutural ( It will start in any one of those gears ). Also you can check to see if you back hatch is fully closed.
Old May 21, 2014 | 6:07 AM
Cougar69's Avatar
The gear lever is in the park position, but as I said there is no light on the dash board highlighting which gear you are in???
Thanks for reply though...
rroyse
May 4, 2016 11:18 AM
bracca
Jul 12, 2009 6:14 PM
G&b
Jul 9, 2009 11:19 AM
kingster888
K5 Blazer
Mar 2, 2008 5:50 PM
