TrailBlazer 2002-2009
A/C exterior temp display
Old Jul 16, 2008 | 3:34 PM
Aberry's Avatar
Default A/C exterior temp display
Hello!
I'm pretty new to the site but truly appreciate that this forum is available, as I have been able to do several repairs and maintenance on my own. However, I've recently put new coolant into my vehicle and although it's only happened a few times, the exterior temp will change to a minus (-) degrees and the air will begin to run warmer.Is my thermostat going out or what?
Thanks to allwho respond!
Old Jul 17, 2008 | 12:06 PM
rbarrios's Avatar
Default RE: A/C exterior temp display
checkout trailvoy.com
theres a few threads there with pics on how to replace. its a $20 part.
the thermostat and engine temp sensor are separate from the ext temp sensor.
Old May 20, 2011 | 8:03 PM
wayne adkinson's Avatar
ex sensor ac driver side mounted front of grill under black plastic rad plate
Old Jun 7, 2011 | 11:29 PM
23rcfd's Avatar
2003 trailblazer also haveing a problem with a/c turning off ext temp tells me its -31 outside so a/c stops would this be a ext temp sensor
Chris777
Cobalt
Oct 27, 2015 4:13 PM
VandyFan
Dec 15, 2014 3:56 PM
AAHTahoe
Dec 19, 2007 5:55 PM
wildfireracing
Jun 29, 2007 12:20 AM
