TrailBlazer 2002-2009
Check engine light for low than normal collant temperature
Old Nov 25, 2011 | 11:54 PM
cupofchicken's Avatar
Question Check engine light for low than normal collant temperature
My check engine light comes on periodically throwing a code for the coolant temperature being lower than normal even though the temp guage is always in the same normal spot at about 180ish and fluids are all full at propper level. I'm thinking coolant temperature sensor maybe? :/
Old Nov 26, 2011 | 10:23 AM
EinST's Avatar
What's the code? Freeze frame data available with ECT value?
Old Nov 26, 2011 | 9:22 PM
MDTAHOE's Avatar
Professional Mechanic
PO128 Coolant thermostat below regulating threshold?
Very common on these trucks. Make sure fan clucth is not staying locked always. Make sure coolant is full. 98% of the time replacing the t-stat fixes it. The code means it is not getting hot fast enough.
Old Dec 24, 2011 | 8:28 AM
recondrill's Avatar
You have a thrmostat that is stuck open. If the engine does not warm up within a specified amount of time, the SES light will come on. Its an easy fix, remove DS tire, use a few extentions to access the 2 bolts that hold on the T-stat and replace.
You will need to loosen (not remove) the alternator to gain access to bolts. It's about a 2 hour project.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
RazzMaTazz
Mar 18, 2015 7:09 PM
rondo
Feb 21, 2012 10:54 PM
Rodrigo
Feb 12, 2012 10:51 PM
bdbrault
Mar 10, 2008 12:36 PM
