TrailBlazer 2002-2009
Difficulty removing clutch fan
Old Mar 15, 2021 | 10:57 AM
the Brain's Avatar
Default Difficulty removing clutch fan
07 saab 97x 5.3i same as V8 trailblazer.
Can’t hold water pump from turning this water pump is smooth on front there aren’t 4 bolts on the water pump pulley. there aren't any holes to insert a tool in the pulley either.
Here is the tools I got from advance auto no one there knew how to use these tools.
The big wrench isn’t an exact fit on the clutch fan nut there’s a possiabilty of rounding it off if it’s on real tight.
I'm starting to think I have the wrong tool if I remember correctly it's called a spanner wrench which I've never used either.
Please need advice to lock down waterpump pulley.
of rounding it off if it’s on real tight.Please need advice to lock down waterpump pulley. thanks for advice
additionalley are the 6 cylinders fan the same as the L33 v8 5.3litre engines fan? this fan is kindof pricie to replace. I may be able to recycle from the junkyard.
warthogcrewchief
Jul 7, 2024 3:29 PM
pdrayton
10
May 5, 2024 2:27 PM
Larrycarol
Jun 5, 2016 3:23 PM
Salto_jorge
Mar 13, 2016 4:34 PM
robertmalibu
Feb 27, 2008 8:41 PM
