TrailBlazer 2002-2009
Disconnecting VSS temporarily fixing Transmission slip? Why?
Old Sep 10, 2019 | 8:40 PM
reedjor's Avatar
Default Disconnecting VSS temporarily fixing Transmission slip? Why?
Helping my friend with an 04 GMC Envoy XUV. It is presenting with the ever-popular 4l60e issue of not wanting to shift, and revving high but not speeding up past ~30 mph. But it temporarily went back to working correctly when I accidentally disconnected the VSS!
This is the full story starting with the list of things I have read about in all the forums as possible causes:
  1. 3-4 clutch pack
  2. Middle case leak in the 2nd gear apply circuit
  3. Shift solenoid(s)
  4. EV clutch fan
  5. 3rd and 4th actuator piston
  6. 3rd accumulator check ball
  7. PCM wiring harness
  8. Transmission internal wiring harness
  9. Loose wire somewhere
I read a guide that suggested removing the GREEN trans connector to force the XUV into limp mode. This was supposed to show us whether the 3-4 pack was fried- if it was the XUV should slip and not go anywhere.
Well, my clever self disconnected the VSS instead. My friend drove it around the parking lot as planned before it occurred to me I did wrong. I reconnected the VSS and waddayaknow, it shifted as it should for a few minutes! Very much the opposite of what I expected. However, he did get ABS dash warnings and I lost some credibility for pulling the wrong connector. I will add that this was a while ago, so I can't remember if it shifted right immediately after I pulled the VSS or only after I plugged it back in. It now has C0201, C0550, C0055, and P0502 codes.
Now, why would pulling the VSS and plugging it back in allow the XUV to shift as it should past 30 mph (we think, we didn't get on roads to go much faster than that, but the trans acted like it was civilized again)? Also, this was temporary; after a while it struggled again. Finally, it has returned to the original state of revving past 30mph with no shift.
Is the trans briefly shifting correctly a clue that it is not mechanical? Could it have been in limp mode this whole time? Or is intermittent restored function to be expected with the likely mechanical causes of this issue?
Old Sep 10, 2019 | 9:14 PM
may have put the trans in failsafe...it may up the line pressure...if the shifts are more harsh the line pressure is higher.
tloftus
May 19, 2024 6:19 PM
Gary Chandler
2007 - 2013 (GMT900)
Jun 6, 2019 10:25 AM
mz0dw4
1988 - 1998 (GMT400)
Feb 28, 2017 11:40 AM
erhinebo
20
Feb 15, 2017 10:29 AM
vincent52100
Jan 11, 2016 1:17 PM
