TrailBlazer 2002-2009
Fuel knock
Old Feb 20, 2021 | 5:54 PM
Timothy.Johnson's Avatar
Default Fuel knock
I have a 2008 trailblazer with the 4.2L. It’s had a misfire on cylinder 1 for a while but only at idle, when you give it gas it goes away. I checked compression on all cylinders and they’re good. There is no oil on the plugs or the coil packs. I was driving the other day and it all of a sudden went into limp mode. The check engine light, the wrench light and the reduced power light came on. It has a fuel knock at idle pretty bad and will shut off when put into gear. But when I crank it a few minutes later it runs fine until I drive it for about ten minutes then all the lights come back on and starts knocking at idle again. Any help would be nice.
Old Feb 20, 2021 | 6:57 PM
kevinkpk's Avatar
Do you have any dtc codes?
Old Feb 20, 2021 | 11:02 PM
Default Codes
Yes it does. P0301 x2, P0171, P2135
Old Feb 21, 2021 | 7:56 AM
kevinkpk's Avatar
P2135 is throttle position sensor, I'd look at that first as it could be causing the other misfire, and lean bank 1.
Old Feb 24, 2021 | 4:14 AM
chem_man's Avatar
15 Year Member
As a quick check, unplug the electrical connector going to the electronic fan clutch. If the reduced power light goes out and your engine functions normally again, then you have a bad fan clutch. Both the electronic throttle and the electronic fan clutch share the same 5 VDC reference voltage. If the fan clutch goes bad, it draws down the 5 VDC reference signal and the engine goes into limp mode and the reduced engine power light comes on.
Darrick Ball
May 31, 2018 9:48 AM
Schoolersteve
Nov 15, 2013 2:56 PM
blackbus1
May 9, 2010 9:12 PM
lroewer
Oct 24, 2006 8:16 AM
jakwi
Feb 19, 2006 3:03 PM
