TrailBlazer 2002-2009
Gas tank replacement problem
Old Jan 3, 2013 | 8:32 PM
ras282's Avatar
Default Gas tank replacement problem
I have a 2003 Trailblazer ext that im replacing the fuel tank because the filler neck cracked. So I've had a hard time finding the right tank to fit but after weeks looking I found one. The only thing wrong is that the tank is from a 05 model which in 05 they changed it to a no-return fuel system. So I need to know if there is any way I can make this work in my 03.
Old Jan 3, 2013 | 11:45 PM
Rockauto sells a filler neck for the 03 Trailblazer. Check it out, it might help you. Here is where you can find it. Paste it into the address bar.
RockAuto Parts Catalog
ahearnm
Mar 19, 2023 6:37 PM
dcoperator
Apr 17, 2016 10:45 PM
grain bin painter
27
Mar 21, 2014 6:08 AM
91Wwife
Jul 11, 2006 8:58 PM
Nomad76lj
May 10, 2006 10:15 PM
