TrailBlazer 2002-2009
heat/ac fan hum
Old May 26, 2008 | 7:03 PM
twenty8's Avatar
Default heat/ac fan hum
I have a 2003 Trailblazer where the fan just started humming with a low pitch and it definitely adds volume to the system when it's on - same noise whether it's on heat, a/c, or just the vent fan. It was working and then suddenly the hum started - yet the fan is still blowing air just fine. It is obviously coming from the blower motor - wasn't sure if this was a sign of it getting ready to quit on me or if it was something else anyone was knowledgeable about. Any ideas on how to fix it?
Old May 27, 2008 | 7:03 AM
shawnvw's Avatar
Banned
Default RE: heat/ac fan hum
Sounds like it might be out of balance, or a bearing is going on it. If its out of balance, there might be leaves or some other junk in it, or a weight has come off of the blades. If the bearing is bad, you would CAN get it fixed, but its usually cheaper to buy a new motor
bluegold
Apr 6, 2012 2:25 PM
Sainfate
Jan 4, 2012 8:49 AM
thehig
Uplander
Nov 26, 2009 9:11 PM
Mud_Truckin
May 15, 2009 9:46 AM
tumark
Apr 15, 2007 12:58 PM
