TrailBlazer 2002-2009
Help needed!
Old Aug 26, 2012 | 2:44 PM
Blackout51's Avatar
Default Help needed!
I was leaving my house and while pulling away I felt a loss in power and it started shaking bad and the check engine light was flashing, so I pulled back into the garage and turned it off but the code goes away when I idle though you can smell it running rich and it idles really rough. Any ideas what I can do to check the code? I pulled all the plugs and they all look good so I'm assuming it's a bad coil pack I just am not for sure! For the last few weeks it has been idling somewhat rough and shaking when I take my foot off the brake and let it idle forward but it went away above 5 mph and drove normal.
Old Aug 26, 2012 | 3:47 PM
Blackout51's Avatar
I just got a p0300 code with my code checker
Old Aug 26, 2012 | 6:32 PM
maxxman04's Avatar
p0300 is the random/multiple cylinder misfire code. which could be a few things. coil is very possible. typically if a plug or injector is bad you will get a misfire code for that specific cylinder. but random misfire is usually coil.
Old Aug 26, 2012 | 10:42 PM
Blackout51's Avatar
But how do I know which coils to change? If its multiple random misfire wouldn't that mean more than one? I just changed the o2 sensors and that did nothing, I had planned on changing them anyways
Old Oct 20, 2012 | 4:36 AM
moonlytr's Avatar
try catilytic converter mine loss of power woouldnt shift right.take a infered tempature gauge while engine has been running for 15 minutes behind cat should be 75 to 100 degrees hotter then be4
RickG
Nov 9, 2006 7:35 AM
86Caprice
Oct 10, 2006 8:31 PM
cbmontgo
May 29, 2006 1:23 PM
st3ph3n
May 22, 2006 11:01 AM
Soulcrusher
Feb 25, 2006 9:21 AM
