TrailBlazer 2002-2009
key stuck in ignition
Old Mar 21, 2015 | 2:48 PM
wesb81's Avatar
Default key stuck in ignition
2003 trailblazer with 5.3l v8 .... i started the vehicle my abs, parking break light and service 4whl dr light was all on i turned the vehicle off and immediately attemoted to start the vehicle again and i got absolutely nothing the radio all accessories lights everything comes on but when i try to start it wont do anything and the key is stuck in the ignition the vehicle does have an aftermarket clifford venom sst alarm system in which i do not have the remote for can the alarm lock up the vehicle so the key wont come out or start but everything comes on and what are other possible problems i may be having thanks in advance for assistance
Old Mar 21, 2015 | 2:56 PM
wesb81's Avatar
also to add i tried replacing the battery and the ignition switch wont turn all the way back i had to unhook the battery
Old Mar 22, 2015 | 11:19 AM
Bookumdanno's Avatar
I'd start checking all the grounds.
Old Mar 22, 2015 | 6:43 PM
poncho62's Avatar
Sounds to me like you have a problem with the ignition switch itself. Wiggle the shift lever....might not be all the way into Park
gman1374
Camaro
Feb 19, 2010 12:05 PM
abren
Cobalt
Feb 21, 2008 7:22 PM
otacon28
Mar 11, 2007 1:32 AM
